IamNaga
Aug 02, 2021Tutor
Netgear Orbi Voice (RBS40V) replacement adaptor
Hi, I bought my Orbi Router in USA which comes with Orbi Voice (RBR40V). And recently I moved to India. After few hours of usage in India, the Orbi Voice adaptor melted and stopped working. Then i r...
IamNaga
Aug 02, 2021Tutor
Thanks plemans for responding. Sure, I will give it a try in local stores near me. The hardest part with online is finding the right polarity which i a not able to find any.
michaelkenward
Aug 03, 2021Guru - Experienced User
They are out there, believe me. The problem is in finding one.
The "voice" satellite is rare in having a 19 volt adapter. (It is also on the CBR750 Cable Modem Router.)That could be the challenge. They are, though, pretty common on laptops.
One option is to go for something that provides set of different tips. There are also multi-voltage, switchable polarity adapters.
You can also find adapters that proclaim that they are compatible with various Netgear devices.
