jips11in
Oct 29, 2020Aspirant
Netgear Orbi WiFi 6 RBK852 vertical coverage through linters
How much vertical coverage through concrete rebar slabs I can get using Netgear Orbi WiFi 6 RBK852 ? Can it cross two concrete rebar slabs i.e 2 floors say from 1st floor to 3rd floor (vertical dista...
Oct 29, 2020Guru - Experienced User
No experience with that however i kinda doubt much signal will travel thru that kind of concrete and steel. :smileyembarrassed:
How thick are these slabs?
- jips11inNov 06, 2020Aspirant
Including floor titles the slab thickness would be 8-9 inches. Finally purchased it and router and satellite can be connected on wifi backhaul with just one floor vertical distance. It dosen't work with two floor distance. So I would need one satellite for 3rd floor.
- FURRYe38Nov 06, 2020Guru - Experienced User
Probably. I would make it wired if possible:
