Tiberius123
Oct 03, 2020Follower
Netgear Orbi WiFi 6 RBK852
Hello, I want to buy the Netgear Orbi WiFi 6 RBK852. The problem I have is that i will have thermostats https://www.livolo-deutschland.de/epages/80880046.sf/de_DE/?ObjectPath=/Shops/80880046/Product...
Mstrbig
Oct 03, 2020Master
Tiberius123 wrote:Hello,
I want to buy the Netgear Orbi WiFi 6 RBK852. The problem I have is that i will have thermostats https://www.livolo-deutschland.de/epages/80880046.sf/de_DE/?ObjectPath=/Shops/80880046/Products/LX-1001-Raumthermostat-12 that only run on 2,4Ghz and not on 5Ghz.
Is there a way, that it is possible to adjust via the orbi app different devices to the different frequencies - if not does it mean, that my thermosthats wont work? Then i cant buy the orbi mesh system.
Thank You for Your help.
The system does not determine the 2.54 or 5GHZ, except for strength and distance.
If your thermostat or any device only supports 2.4Ghz, they will connect 2.4Ghz. If they supports 5Ghz, they will connect 5Ghz, unless they are below a level threshold to make a 5Ghz connection, then they will connect 2.4Ghz..
