Stevey1956
May 16, 2022Follower
Netgear orbi wifi mesh sytem
Hi,
Considering purchasing a mesh wifi system but i am currently with Sky Broadband and have Sky Q plus a mini box.
Is this system compatible with Sky Q?
I have read varying reports?
Thanks,
Steve.
1 Reply
Kind of depends. Does this ISP have a modem or ONT that has built in router? If so, his would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-ModeYou might ask them if adding a external router system will work with there hardware and if any of there hardware can be replaced by a Orbi system or if option #2 will be best if you want to use a Orbi system.
