solarisfps
Jan 23, 2022Aspirant
Netgear RBR750 x2 backhaul/daisy still connecting via 5g
I live in a 3 bedroom house and i have the Orbi RBR 750 router and 2x satellite i have a cable running from my bedroom downstairs to the kids room to create a backhaul. Then there is a satellite in t...
solarisfps
I ran a cat 6 cable from upstairs to the kids room and terminated the ends myself. I used a rj45 tester which passed the test.
There are no switches in between the router and the satellites.
The only thing I can think of doing is reterminating the 1st connector I did as maybe there is any issue not sure.
Jan 23, 2022Guru - Experienced User
Just try moving the satellite first for testing. If it works, you know its the cable run and you can try replacing the ends. Most people have a spare 6ft cat 5e (or better) cable sitting around.
Its always good to test if its the cable or the satellite.
- solarisfpsJan 23, 2022Aspirant
Ive moved the satallite upstairs it shows the connection as wired now backhaul status is out of sync for the sattelite so not sure what is going on with this as well.
- plemansJan 23, 2022Guru - Experienced User
So when you move it it shows as wired? You can factory reset the satellite and re-sync it and that should fix the error you have.
But it kind of indicates that the wiring that was ran has something wrong with it. You can recheck the ends.
I have done as you have suggested i reterminated the upstairs plug and used a laptop to test the connection on the other end. I ran 2 speed tests and was getting in excess 900mb (1gb connection). I then synced the satillete upstairs and moved it downstairs. When it booted up it showed wired for around 1 min and then changed to wireless itself. I have no idea what to do now.
