GJSchaller
Apr 06, 2025Guide
Netgear RBR850 - trouble with Port Forwarding
I just set up an Orbi 850 series Router / Satellite system in my home. The basics all work, I have Internet, Wi-Fi is working, etc. Model Name Device Name Current Firmware Version RB...
- Apr 08, 2025
Finally figured this out - it was a DNS issue, specifically related to IPv4 & IPv6.
When I installed the new router, I rebooted my cable modem as a part of the process. When this happened, my home IP changed - for both v4 and v6. I caught the v4 change, and updated my Public DNS records, so it worked from the outside world for any device using IPv4, but not v6. Once I realized what happened, I updated my DNS records for v6 as well, and everything is working again.
It wasn't an issue with the router itself, so much as an issue that came up while installing it with other systems
CrimpOn
Apr 06, 2025Guru - Experienced User
The DDNS process indeed resolves to the correct IP address.
GJSchaller wrote:
the DMZ appears to be working (My websites are visible), but the Port Forwarding to 253 does not seem to be working.
The virtual server (IP 10.0.0.240 which is the same as the DMZ IP value) is working. i.e. the TrueNAS web server appears, asking for login credentials.
There should be an option to log when port forwarding is activated (on the Advanced Tab, Administration Menu, Logs. Does anything appear there?
Is it possible to capture the network connection for the host computer, IP 10.0.0.253? (Wireshark or similar) Definitely sure that the host computer still has IP 10.0.0.253 on the new network?
- CrimpOnApr 06, 2025Guru - Experienced User
p.s. FURRYe38 is correct that Netgear released newer firmware for the RBR850:
Click on Previous Versions
https://www.netgear.com/support/product/rbr850/#download
I doubt very much that the firmware release has much to do with this specific situation. But, when customers contact netgear support, one of their first questions is likely to be, "is the firmware current?" Before rushing to update, please be aware that there are a number of very long discussions on the forum about the newer version 7 firmware for the 850 product. A number of users have tried v7.2.7.15 and deliberately "gone back" to a previous version.
- GJSchallerApr 06, 2025Guide
OK, so the latest version available from the UI is not the latest version available online - that's a step in the right direction.
Let me get that upgraded, and work from there.
