NeepsTatties
May 18, 2022Aspirant
Netgear RBS850 - 4.6.3.16 Firmware patch failure? FIXED!!!!
Help! Following some short wifi disconnects, I tried to patch to latest firmware (4.6.3.16 from Netgear site (note this page links to the RBR firmware not the RBS version but the release note has th...
NeepsTatties
Ok, not sure what I did but it suddenly sorted itself. It could have been the double hardware reset or long period of power off, or proximity to the router - no idea!!!!!
- FURRYe38May 18, 2022Guru - Experienced User
For both RBR and RBS FW, use this site for future reference:
https://www.netgear.com/support/product/RBK852.aspx#download
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
