David9
Aug 08, 2023Aspirant
Netgear RBS850 still keeps going magenta
So I reported this previously (but hell if I can find the previous posting). I have an RBS850 orbi solution with one satellite. It is over a year old (so has hardware support but bugger anything else...
Aug 08, 2023Guru - Experienced User
In AP mode, the router is getting its wan/ip info from the primary router its connected to. The magenta is indicating there's an issue with that.
What do the LEDs on my Orbi router and satellite mean? | Answer | NETGEAR Support
Maybe you're lease time is expiring on the router that's acting as primary. Maybe go into it and set it with a static IP address.
Now you put the RBS is going magenta. Just the satellite or the router too?
- David9Aug 08, 2023Aspirant
Thank you. I have already set the IP address of the Orbi router to be static and it still occurs. It is the router that is going magenta.
