florus
Mar 07, 2025Aspirant
Netgear router in AP mode constant purple light
Hi, I have installed my orbi rbr760 router and sattelite. I put the router in AP mode and connected it to my Odido router (with wifi turned off). I used lan4 from my Odido router to an Ethernet connec...
Mar 07, 2025Guru - Experienced User
Use of the yellow WAN (Internet) port on the RBR to connect to the host router while in Router or AP mode is required.
florus
Mar 16, 2025Aspirant
This fixed it indeed lol.
- FURRYe38Mar 16, 2025Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
