florus
Mar 07, 2025Aspirant
Netgear router in AP mode constant purple light
Hi, I have installed my orbi rbr760 router and sattelite. I put the router in AP mode and connected it to my Odido router (with wifi turned off). I used lan4 from my Odido router to an Ethernet connec...
florus
Mar 16, 2025Aspirant
This fixed it indeed lol.
Mar 16, 2025Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
