Sapper9
Mar 03, 2023Aspirant
Netgear Satellite RBS750 - Connection failure
Trying to connect my Panasonic ToughBook with Windows 10 Pro to my existing Netgear wifi, but the laptop does not see any Netgear connection. How to help my computer to find the Netgear connectio...
Mar 03, 2023Guru - Experienced User
What wifi card is in the laptop?
what driver is installed for that card?
Some of the older wifi cards have issues with AX routers.
options?
1. find out the card, see if the manufacture of the card (not the laptop) has a newer driver that fixes those issues.
2. disable AX on the router (which ruins the point of an AX router)
3. upgrade the wireless card or install a usb based card.
Sapper9
Mar 05, 2023Aspirant
Thanks for your very kind reply.
Unfortunately this fix is somewhat beyond my technical capacity - I am unsure of where to look for the wireless card specs. I looked in Control Panel, but it's not there.
Best regards
Sapper9
