Sapper9
Mar 03, 2023Aspirant
Netgear Satellite RBS750 - Connection failure
Trying to connect my Panasonic ToughBook with Windows 10 Pro to my existing Netgear wifi, but the laptop does not see any Netgear connection. How to help my computer to find the Netgear connectio...
Sapper9
Mar 05, 2023Aspirant
Thanks, David.
No solution found so far, but I live in hope!
All the best
Sapper9
davidk1952
Mar 05, 2023Luminary
To look for your network adapter type Device Manager in bottom search bar of windows 10, they scroll down to Network adapter and expand it, the first line should show you what network adapter that is installed. Right click on the network adapter and a box should come and let you know if the adapter is working or not.
You can also run Network troubleshooter Windows 10: Run Troubleshooter to Fix Network Connection Problems - My Microsoft Office Tips (myofficetricks.com)
Did this notebook connect to wifi before ? How old is the notebook? On some notebooks there is a key that you can shut wifi off, check your owners manual and see if there is a key on the laptop that actually turns wifi on and off.
See if any of this works for you.
- plemansMar 05, 2023Guru - Experienced User
I looked up that laptop and it can with potentially several different cards.
so go into your device manager and find the wireless card.
Post back what card it is and what driver is installed
