Sapper9
Mar 03, 2023Aspirant
Netgear Satellite RBS750 - Connection failure
Trying to connect my Panasonic ToughBook with Windows 10 Pro to my existing Netgear wifi, but the laptop does not see any Netgear connection. How to help my computer to find the Netgear connectio...
Sapper9
Mar 05, 2023Aspirant
Many thanks everyone, for all these answers.
I checked the Network Cards...
They all are OK and using the latest drivers.
I can connect to the home WiFi, no problem.
What I want is to connect to the NetGear booster, so that I can get online upstairs as well as downstairs. The home WiFi is not strong enough to reach upstairs, that's why I bought the NetGear adapter.
Also, I ran the Windows Troubleshooter - but it cannot see any problems, because it thinks I am on the home WiFi. The laptop cannot see the Netgear router, so the troubleshooter doesn't know it even exists.
davidk1952
Mar 06, 2023Luminary
I am now completely confused... what do you mean your connected to the home wifi but not the extender...If you are using a Mesh system ... perhaps someone here can walk you through it because what I know of Mesh systems any satellite (iif that is what your talking about) should not need any configuration once you get system configured... I'm going to step aside and let a mesh expert take it from here...
