MLUCK
Jun 29, 2022Star
Netgear Service is Horrible Horrible Horrible
I own two RBK750's, one each of two homes. For months now, neither has been manageable because I can't access the router either through the web interface nor the mobile app (iOS). So frustrating. ...
MLUCK
Jul 01, 2022Star
FURRYe38 wrote:What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
Looks like it's an Arris BGW210. I've rebooted it too, and still can't access my router. Netgear is zero help.
Can you imagine what would happen if you bought a new car and were unable to access the dashboard or the engine to maintain vehicle? It would never be tolerated. And then the manufacturer said it would take months to repair, during which time you can't contact us without paying. And then they still hadn't fixed it, months later. And so their answer was, "We're trying as hard as we can and we're sorry. We don't know what the problem is, but we're working as hard as possible." Just pathetic. Netgear has trained me to despise Netgear.
Jul 02, 2022Guru - Experienced User
So you'll need to factory reset and setup from scratch.
You'll need to save off a new back configuration to file. Always do this each time you make a change to the system. Never hurts to have too many backup configurations on file.
- MLUCKJul 02, 2022Star
Factory reseting means spending days reconfiguring. But I guess I don't have a choice. So I've been sitting here all afternoon following Netgear's instructions to factory reset. I get the Amber LED after holding a paper clip into the reset hole for 10+ seconds, but then the router reboots with the same old SSID, not factory reset. Tried calling Netgear. They are worse than useless.
- CrimpOnJul 02, 2022Guru - Experienced User
Just to be clear, the Power LED turned amber and then began to flash?
- MLUCKJul 04, 2022Star
YES exactly - the LED turned Amber and then began to flash (pretty quickly)
- FURRYe38Jul 02, 2022Guru - Experienced User
Have 1 wired PC connected to the RBR. Turn OFF all RBS and disconnect ALL wired devices from the RBR. Disconnect the RBR from the ISP modem.
Press the reset button for 20 seconds then release.
Use a web browser and poing to 192.168.1.1...should bring up a setup wizard.
FURRYe38 wrote:Have 1 wired PC connected to the RBR. Turn OFF all RBS and disconnect ALL wired devices from the RBR. Disconnect the RBR from the ISP modem.
MLUCK wrote:Factory reseting means spending days reconfiguring. But I guess I don't have a choice. So I've been sitting here all afternoon following Netgear's instructions to factory reset. I get the Amber LED after holding a paper clip into the reset hole for 10+ seconds, but then the router reboots with the same old SSID, not factory reset. Tried calling Netgear. They are worse than useless
This worked, thank you. Why is it that you all are so helpful (and quick), yet Netgear support Is so slow and useless? Shocking to me.
One of my satellites is still showing as "Out of Sync" -- I've tried to sync a dozen-ish times. I've followed all the tips in the community, but no joy. Any ideas?
