1sbl
Jan 01, 2022Follower
NETGEAR WiFi 6 Orbi AX4200 WiFi 6 (RBS750) sometimes giving "request timed out" in cmd (windows)
Hey, I couldn't find any similair problems so I decided to make a subject myself. (For some reason I couldn't find the model while filling this in, router info is in subject). The problem is that,...
Jan 02, 2022Guru - Experienced User
How are you testing? wired or wireless to the RBR or RBS?
1sbl wrote:
Hey, I couldn't find any similair problems so I decided to make a subject myself. (For some reason I couldn't find the model while filling this in, router info is in subject). The problem is that, at any random moment, on any normal day, it just does something weird which disconnects me from different servers and takes websites to load much longer. If I run a ping test in cmd (windows), there are some lines that say "request timed out". It even gets as bad as doing the thing in the picture below for hours or days. Using windows or linux makes no difference, same thing if I use different devices or using a LAN cable.
But If I turn our internets provider modem of and on, this problem stops for a few hours or just for the rest of the day. The problem only comes from the orbi routers because I've tested this on the modem aswell, with no problems (note' modem and orbi router is connected by cable). (This issue has been happening for a while now.) I'd be glad if anyone might have any idea whats causing this problem
