Clivem4
Dec 14, 2021Follower
Netgearorbi rbk 852
Hi thinking of purchasing this router and satellite from the USA will this work okay in the United Kingdom with just the changes to the power supplies any advice would be appreciated thank you
- Dec 14, 2021
Should work if you find the right power supplys to use for the UK region.
I recommend buying from some place that has a good refund policy.
Dec 14, 2021Guru - Experienced User
