Wiltronics
Jul 27, 2020Aspirant
Network management App and Web user interface
Recently bought the RBR750 — Orbi WiFi 6 System AX4200 with 2 RBS750. Router setup in AP mode and in average 8 devices connected using 1Gbps Fiber Internet connection. Experience intermittent Networ...
- Aug 22, 2020
Last week Saturday updated the RBK753 to Firmware Version, V3.2.16.6_1.4.4
since then both the App and Web GUI working perfectly fine. Through the week extensively testing with downloads and upload and testing the App and GUI no problems detected.
Wiltronics
Aug 04, 2020Aspirant
Netgear support; any findings and updates on this topic?
Aug 04, 2020Guru - Experienced User
What version of FW are you using? v32 is most current.
Are you using a Dynamic IP address or a Static IP address configuration on the RBR when in AP mode?
What is the mfr and model # of the main host router the RBR is connected to in AP mode?
- WiltronicsAug 05, 2020Aspirant
Support recommends to apply Hot Fix on both Router and Satellite, claims it fixes the issue. Not able to do this until late friday due to working from home and possible impact after applying the fix.
Current Firmware version V3.2.15.25, all dynamic IP.
The Router in AP mode is connected to ONR of Huawei HG8244H
When Hot fix doesn't work shall apply static IP to Orbi router/APmode.
- FURRYe38Aug 06, 2020Guru - Experienced User
Keep us posted.
- WiltronicsAug 12, 2020Aspirant
May I know when the App isn't able to connect anymore does the Web Interface still work?
