Neville58
Sep 21, 2021Aspirant
Network map changes and satellite glowing blue
Hi, I'm new to this community but hoping someone can shed some light on this strange issue. RBR850 - FW V4.6.3.16 and both RBS850 have FW V4.6.3.16 Orbi App is V2.11.6.0 on iPhone Since install...
Blanca_O
Sep 21, 2021NETGEAR Employee Retired
Hi Neville58
Welcome to NETGEAR Community!
Here's a reference What do the lines and colors in the Orbi Network Map mean : https://kb.netgear.com/000061800/
For iOS:
Solid line: Ethernet connection
Dashed line: WiFi connection
Green dot: Connected
Amber dot: Poor connection
Magenta dot: Not connected
Is the "Study" Satellite connected to the router via wired or wireless?
Please turn off both router and satellite and check if it will change the status.
For comparison, kindly access router Web UI > Attached devices and check Satellite connection status.
Blanca
Community Team
jmbach
Oct 02, 2021Aspirant
I have the same thing since the last software update. Power cycling the whole system does not solve the issue.
- FURRYe38Oct 02, 2021Guru - Experienced User
Try a reset of the RBR and RBS, leave off for 1 hour or do this over night then setup in the morning. See if a longer power off cycle helps with a reset. Press the reset button for 15 seconds then release. Pull the power adapter after the front LED starts rto blinnk WHITE.
jmbach wrote:
I have the same thing since the last software update. Power cycling the whole system does not solve the issue.- jmbachOct 03, 2021Aspirant
Well a system reset is the last thing that I want to do unless there are no other options. My system uses a wireless backhaul and prior to the update, had noticed no operational changes up until the latest update.
After some experimentation it seems to have resolved for now.
After the last update (4.6.3.16) my RBS850 had a solid blue light that did not go out. It will a couple of times a week revert to flashing white followed by the constant blue light. The RBR850 acted normal.
Tried power cycling the system a couple of times which did not resolve the problem. What worked for me was to connect the RBR850 and RBS850 via a wired backhaul. Now the RBS850 is acting like it should with the blue light going off after a short while. When I have the time, will see if the wireless backhaul will revert back to the original problem or continue to work.
- FURRYe38Oct 03, 2021Guru - Experienced User
Try a reset of the RBR and RBS and setup up from scratch. I'd leave the system OFF for 1 hour if you can then setup.
