Neville58
Sep 21, 2021Aspirant
Network map changes and satellite glowing blue
Hi, I'm new to this community but hoping someone can shed some light on this strange issue. RBR850 - FW V4.6.3.16 and both RBS850 have FW V4.6.3.16 Orbi App is V2.11.6.0 on iPhone Since install...
busjen
Oct 02, 2021Aspirant
I have the same problem with the satellite glowing blue sometimes, this problem came with the last update
Oct 03, 2021Guru - Experienced User
Try a reset of the RBR and RBS, leave off for 1 hour or do this over night then setup in the morning. See if a longer power off cycle helps with a reset. Press the reset button for 15 seconds then release. Pull the power adapter after the front LED starts rto blinnk WHITE.
