Bmehboob1
Jun 18, 2021Follower
Network map/Network connectivity
Firstly, apologies if this has been repeated elsewhere or is an obvious issue. I am not the most technical of persons! I bought an RBK353 wifi system in Feb-21, on my network map it was showing t...
michaelkenward
Jun 19, 2021Guru - Experienced User
Bmehboob1 wrote:
I bought an RBK353 wifi system in Feb-21, on my network map it was showing the router (green dot) connected to satellite 1 (green dot) and satellite 2 (orange dot).
You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here. However, Orbi systems with their satellites aren't much like standard routers, so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
