Renco
Feb 23, 2022Aspirant
Network problems with orbi rbk853
Hi, I've been using my orbi for around 6 moths now, all without problems but lately I've been having some annoying issues. Sometimes my youtube video will randomly stop playing and if i refresh ...
Feb 23, 2022Guru - Experienced User
You might try this firmare version:
New - RBR850 / RBS850 Firmware Version v4.6.7.5 Re... - NETGEAR Communities
I've heard it has a few improvements, fixes.
- RencoFeb 23, 2022Aspirant
Thanks for the tips,
I was able to update the firmware manually but the problems still occurs.
- FURRYe38Feb 23, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Turned off AX mode or 2.4Ghz under Basic tab/Wireless settings.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
