Zipsy
Nov 01, 2020Aspirant
Network Round Trip Time Spikes ever few Seconds on Orbi ax4200 RBR750
When pinging google on command prompt the ping rises occasionally, but when playing games like valorant the network round trip time or ping spikes up every like 2 seconds.
- Nov 17, 2020
Just finished troubleshooting and experimenting with everything I could. The thing that was causing it was actually the power extenders! When changing the router plug into an actual outlet in the wall the wifi was great. It was lightning fast. At least I know now.
Zipsy
Nov 02, 2020Aspirant
When connecting to the modem everything is fine. No ping spikes or anything and I have also contacted my internet provider to see if anything was wrong on their end. Nothing. V3.2.16.6_1.4.4 is the firmware
mschoenf
Nov 08, 2020Aspirant
I am Also having this same behavior while playing wow, with firmware 3.2.16.6
- FURRYe38Nov 08, 2020Guru - Experienced User
What are the ping results if you connect a wired PC to the ISP modem/ONT and use the free trial ping plotter program from pingplotter.com with out the RBR?
mschoenf wrote:I am Also having this same behavior while playing wow, with firmware 3.2.16.6
- ZipsyNov 09, 2020Aspirant
I also talked over the phone with someone at netgear and they didn't seem to have an answer for it.
- FURRYe38Nov 09, 2020Guru - Experienced User
I would probably return the 7 series and try a 8 series to see if the problem follows.
