Donfesta
Jun 07, 2022Follower
Networks changes on my orbi 6 mesh
My Netgear main modem/router has its own wifi name and the orbi 6 has it own network, my security cameras uses the Netgears wifi every once in awhile my cameras go out and find that the network changed to the Orbi network do I have to turn off the Obi wifi so the Netgear router/modem takes over, will the orbis still work using my Netgear router
1 Reply
What Orbi model do you have?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
