Apr 15, 2021Guru - Experienced User
New - Firmware Version 3.2.18.1 for RBR750 / RBS750 Series Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Bug Fixes: Fixes the NETGEAR Armor vulnerabil...
- Apr 21, 2021
FURRYe38 wrote:
Mastra11 wrote:
Hello, the firmware works well, is it stable? I haven't installed it yet.This firmware - 3.2.18.1 - has been very stable on my RBK753S.
I did also turn off IPv6 6 days ago, not sure if that was causing problems before, but with this firmware my Orbi AX system has been rock solid for the past 6 days - no wireless disconnects.
Now I can comfortably sell my RBK53 - I had been holding off since I just got the RBK753S a week and a half ago (last day of sale) and first wanted to ensure the RBK753S was stable for at least a week.
taiwindows9
Sep 27, 2023Aspirant
Thank you for sharing the information about the new firmware release for the RBR750/RBS750 series. I have reviewed the firmware update instructions and it is straightforward and easy to follow.
I have also checked the Netgear security website and there is no information about any specific security vulnerabilities that have been fixed in this firmware release. However, it is always a good idea to keep your firmware up to date to get the latest security fixes and bug fixes.
I will download and install the new firmware on my Orbi AX 750 system and let you know how it works out.
Additional information:
It is important to note that this firmware is only for the Orbi AX 750 series systems, only for manual download and installation. If you have a different Orbi system, please check the Netgear support website to see if there is a new firmware release available for your system.
It is also important to back up your Orbi system configuration before updating the firmware. In case something goes wrong during the firmware update, you can restore your system to its previous configuration.
I hope this information is helpful. Please let me know if you have any other questions.
