Apr 14, 2021Guru - Experienced User
New - Firmware Version 3.2.18.1 for RBR840-850 / RBS840-850 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Bug Fixes: Fixes the NETGEAR Armor vulnerabil...
- Apr 20, 2021
Quite happy with this firmware update 3.2.18.1!
For the Netgear Orbi AX RBK853 (Router + 2 Satellites), it auto-updated under the router admin and works successfully. I rebooted one of the Satellites to get a better connection, was a bit intermittent just after the update, but as soon as restarted all is stable. Fast and strong connection.
I also don't have any more DNS issues, however previously I did setup a 4to6 Tunnel under the router admin as well which helps mostly with that.
Chuck_M
Apr 16, 2021Mentor
FURRYe38 wrote:
This firmware is only for the Orbi AX 840/850 series systems only for manual download and installation.
Let us know how it works for you...
This auto installed on my 850 & sattelites.... I did not manually download or install but it is there.
vajim
Apr 16, 2021Master
wow...that's a rarity. You didn't have to check for updates, click on anything, etc..??
