Apr 14, 2021Guru - Experienced User
New - Firmware Version 3.2.18.1 for RBR840-850 / RBS840-850 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Bug Fixes: Fixes the NETGEAR Armor vulnerabil...
- Apr 20, 2021
Quite happy with this firmware update 3.2.18.1!
For the Netgear Orbi AX RBK853 (Router + 2 Satellites), it auto-updated under the router admin and works successfully. I rebooted one of the Satellites to get a better connection, was a bit intermittent just after the update, but as soon as restarted all is stable. Fast and strong connection.
I also don't have any more DNS issues, however previously I did setup a 4to6 Tunnel under the router admin as well which helps mostly with that.
Apr 16, 2021Guru - Experienced User
Kewl. did you power cycle the system off then back on any or just continue?
Chuck_M wrote:
FURRYe38 wrote:
This firmware is only for the Orbi AX 840/850 series systems only for manual download and installation.
Let us know how it works for you...
This auto installed on my 850 & sattelites.... I did not manually download or install but it is there.
Chuck_M
Apr 16, 2021Mentor
FURRYe38 wrote:Kewl. did you power cycle the system off then back on any or just continue?
I did nothing... In fact, I dont know for how many days it has been installed.... I saw the post here and went and checked what version I had and it was already on the RBR and the three RBS's.
On my friends, I went to the Web GUI control panel and went to admin and Firmware and as it checked for what current version, it offered up the upgrade (where you had to click UPGRADE). Very odd that two exact systems would act so differently.
I have not power cycled nor factory reset.
