Apr 14, 2021Guru - Experienced User
New - Firmware Version 3.2.18.1 for RBR840-850 / RBS840-850 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Bug Fixes: Fixes the NETGEAR Armor vulnerabil...
- Apr 20, 2021
Quite happy with this firmware update 3.2.18.1!
For the Netgear Orbi AX RBK853 (Router + 2 Satellites), it auto-updated under the router admin and works successfully. I rebooted one of the Satellites to get a better connection, was a bit intermittent just after the update, but as soon as restarted all is stable. Fast and strong connection.
I also don't have any more DNS issues, however previously I did setup a 4to6 Tunnel under the router admin as well which helps mostly with that.
Apr 16, 2021Guru - Experienced User
Seems like this is a Major version which NG can auto push to users systems.
Well glad it's working for you then. Might make a new backup to file for this version of FW.
Enjoy. :smileywink:
vajim
Apr 16, 2021Master
So i wonder if there's a auto update for the 750 orbi's?
- MstrbigApr 21, 2021Master
Yes it is available and working flawlessly:
https://www.downloads.netgear.com/files/GDC/RBK752/RBR750-V3.2.18.1_1.4.14.zip
https://www.downloads.netgear.com/files/GDC/RBK752/RBS750-V3.2.18.1_1.4.14.zip
