Apr 14, 2021Guru - Experienced User
New - Firmware Version 3.2.18.1 for RBR840-850 / RBS840-850 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Bug Fixes: Fixes the NETGEAR Armor vulnerabil...
- Apr 20, 2021
Quite happy with this firmware update 3.2.18.1!
For the Netgear Orbi AX RBK853 (Router + 2 Satellites), it auto-updated under the router admin and works successfully. I rebooted one of the Satellites to get a better connection, was a bit intermittent just after the update, but as soon as restarted all is stable. Fast and strong connection.
I also don't have any more DNS issues, however previously I did setup a 4to6 Tunnel under the router admin as well which helps mostly with that.
mmorain
Apr 21, 2021Tutor
I was automatically updated to this firmware, and have been unable to connect to my ISP since then. VLAN tagging was disabled on update, and even after enabling it, I can't connect. I've tried factory reset, reconfiguring, etc. To no avail.
Anyone else have PPPoE + VLAN working?
tak1313
Apr 21, 2021Luminary
I assume you just didn't update your sig line? It says Rbk53, and this firmware is for the AX models.
