Apr 14, 2021Guru - Experienced User
New - Firmware Version 3.2.18.1 for RBR840-850 / RBS840-850 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Bug Fixes: Fixes the NETGEAR Armor vulnerabil...
- Apr 20, 2021
Quite happy with this firmware update 3.2.18.1!
For the Netgear Orbi AX RBK853 (Router + 2 Satellites), it auto-updated under the router admin and works successfully. I rebooted one of the Satellites to get a better connection, was a bit intermittent just after the update, but as soon as restarted all is stable. Fast and strong connection.
I also don't have any more DNS issues, however previously I did setup a 4to6 Tunnel under the router admin as well which helps mostly with that.
skeelo
Apr 21, 2021Luminary
Mine too.
The device list is all wrong now. It’s not showing a number of devices and some of the devices shown are listed under the wrong connection (e.g., wireless showing up as wired, etc).
Otherwise everything appears to be working.
Apr 21, 2021Guru - Experienced User
Did you power OFF the RBR and RBS for 30 seconds then back ON after the FW update?
skeelo wrote:
Mine too.
- skeeloApr 21, 2021LuminaryNo. I did reboot the system via the app.
I have an RBR, 3 RBS, and a busy house. It’s not conducive to run around turning items on and off after an update.
The tech is supposed to work for you, not the other way around!
Sidebar, I know you’re trying to help and appreciate it. My frustration is with the 1-2% of the product that doesn’t work as it should. For what has been spent on this wireless setup I shouldn’t need to moonlight as an IT help desk in my own house.- FURRYe38Apr 21, 2021Guru - Experienced User
Understand. However a power cycle maybe need to let the new FW and system and all the devices take effect. A reboot of the system may not be enough.
Last resort would be a factory reset and setup from scratch. Usually a power cydle should help first off. You may need to also power cycle the devices that are not appearing in the list as well after you power cycle the orbi system to be sure the devices are getting a new connection and seen by the Orbi system.
- skeeloApr 21, 2021LuminaryAssume it’s shut down RBS first, then RBR leaving all off. From there turn on RBR first then RBS?
- MstrbigApr 22, 2021Master
Sidebar, I know you’re trying to help and appreciate it. My frustration is with the 1-2% of the product that doesn’t work as it should. For what has been spent on this wireless setup I shouldn’t need to moonlight as an IT help desk in my own house.I undersdand your frustration, but if you don't follow the normal suggested procedure after an up date, it's like changing your oil on your car and not putting the plug back in. Something will go wrong in most cases. There are so many differrent devices, (my personal system has over 25, from TVs to cameras, PCs, printers and more), that it is always a good idea to reboot all of them after a firmware update.
One other thing I found is everything works better if you use IP address reservation. No more failed to connect devices because the expected IP address was already assigned.
