Feb 22, 2025Guru - Experienced User
New - Orbi RBR/RBS 850/860 and 960 series Firmware Version 7.2.7.15 Released
Enhancements: 02/21/2025
Added Router Protection support.
Bug Fixes:
Fixed a WiFi connection stability issue.
Fixed various bugs.
Security Fixes:
This firmware addresses securit...
KMDonlon
Feb 27, 2025Virtuoso
So far, so good. Seems like a few 2.4 devices are a bit finiky to connect quickly... will keep an eye out.
Also, digging the new icons!
- KMDonlonFeb 27, 2025VirtuosoWell, I reverted back to V7.2.6.31_5.0.24. Odd connection issues with the satellite and when I downgraded the firmware of the satellite first it would auto update back to 7.2.7.15 within a minute or two. Definitely some major bugs.
- FURRYe38Feb 28, 2025Guru - Experienced User
Which orbi model system do you have?
I'd give a factory reset and setup from scratch after v.15 is applied. If your seeing issues, a FR would be needed to help check this. Not a major issue if you don't check this a bit more.
Mines been online since the other day. FW was applied, power cycled, the FR and setup from scratch with 3 RBS wirelessly connected. Not seeing any issues at the RBS. I have a R7960P in wireless bridge mode connected to on of the RBS. I was watching TV with my DISH Joey connected ethernet to the R7960P just fine yesterday.
KMDonlon wrote:
Well, I reverted back to V7.2.6.31_5.0.24. Odd connection issues with the satellite and when I downgraded the firmware of the satellite first it would auto update back to 7.2.7.15 within a minute or two. Definitely some major bugs.- F_VFeb 28, 2025Luminary
So interesting that after upgrading to .15 that some people have issues and others do not. I updated my firmware on 2 RBS and the RBR, power cycled each one, and it's been rock solid since. I'm in AP mode with a Ubiquiti gateway managing clients and other services.
