Feb 22, 2025Guru - Experienced User
New - Orbi RBR/RBS 850/860 and 960 series Firmware Version 7.2.7.15 Released
Enhancements: 02/21/2025
Added Router Protection support.
Bug Fixes:
Fixed a WiFi connection stability issue.
Fixed various bugs.
Security Fixes:
This firmware addresses securit...
Mijnheer1970
Mar 07, 2025Tutor
Hi,
Noticed twice today and yesterday evening that the RBR850 is rebooting with this new version. Worked stable for one-two days but I am now experiencing these issues? Any thoughts?
Mar 07, 2025Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.
After updating mine, I power cycled mine and then factory reset and setup from scratch. After getting it all setup, been online and working great for me.
Mijnheer1970 wrote:
Hi,
