Feb 22, 2025Guru - Experienced User
New - Orbi RBR/RBS 850/860 and 960 series Firmware Version 7.2.7.15 Released
Enhancements: 02/21/2025
Added Router Protection support.
Bug Fixes:
Fixed a WiFi connection stability issue.
Fixed various bugs.
Security Fixes:
This firmware addresses securit...
Mar 09, 2025Guru - Experienced User
854 series working great on this version of FW:
- musicman0725Mar 10, 2025Apprentice
This update has been working great on my RBR850 series. Updated the satellites first and then the router on Friday night. It has been running solid the entire weekend without needing to reboot.
- KMDonlonMar 10, 2025VirtuosoWhat firmware version did you guys have loaded before updating? I recall a lot of folks had issues with V7.2.6.31 and were back to running V7. 2.6.21...
I upgraded from V7.2.6.31. The only issue I had on that version is occasionally an iOS device (iPhone/iPad) would not be able to connect to the Orbi WiFi unless I toggled private wifi address on/off (it is recommended to have this setting off, but the issue would still happen, so the workaround is to flip it on and then turn it off later). So far I have not seen any devices run into this issue since updating.
