Feb 22, 2025Guru - Experienced User
New - Orbi RBR/RBS 850/860 and 960 series Firmware Version 7.2.7.15 Released
Enhancements: 02/21/2025
Added Router Protection support.
Bug Fixes:
Fixed a WiFi connection stability issue.
Fixed various bugs.
Security Fixes:
This firmware addresses securit...
JustNeedSpeed
Mar 29, 2025Aspirant
I have RBRE960E Router and 3 RBSE960B Satellites. Ever since the February update, the router and satellites are rebooting 6-10 times a day at random times? I have manually factory reset all the units, and reset up the network. However it is still causing issues. It was rock solid prior to the update?
Firmware version 7.2.7.15
Retired_Member
Mar 29, 2025So far the update has been fine for me with the RBKE963B, I haven't experienced any reboots, do you have and specific config you are using or just mainly the default settings?
