Feb 22, 2025Guru - Experienced User
New - Orbi RBR/RBS 850/860 and 960 series Firmware Version 7.2.7.15 Released
Enhancements: 02/21/2025
Added Router Protection support.
Bug Fixes:
Fixed a WiFi connection stability issue.
Fixed various bugs.
Security Fixes:
This firmware addresses securit...
spewak
Apr 02, 2025Luminary
I am experiencing dropouts on both wired and unwired. I am going to go back to the stable .21 firmware as it was completely stable.
Apr 02, 2025Guru - Experienced User
I would factory reset and setup from scratch. I saw 30 days good solid up time with no issues on my 850 series on this version of FW.
- spewakApr 03, 2025Luminary
I'll give a factory reset a try Furry. Thanks as always
- FURRYe38Apr 03, 2025Guru - Experienced User
- Retired_MemberApr 15, 2025
One thing I’ve noticed on the router debug page is that CPU utilization is now (around 6%), which is roughly half of what it was before on the previous firmware (around 12%). Interestingly, both satellites are still showing (about 12%) CPU utilization as they were before on the previous firmware. Just thought I’d mention it.
- spewakApr 21, 2025Luminary
Factory reset both RBR and RBS and then updated to the new version. Seems okay.
- FURRYe38Apr 21, 2025Guru - Experienced User
Good to hear. Mine ran for a full good 30 days with out issues. Wireless then Ethernet BH.
Sans the IPv6 problem for some, seems to be good for those that don't require IPv6 features. 👍
