Feb 22, 2025Guru - Experienced User
New - Orbi RBR/RBS 850/860 and 960 series Firmware Version 7.2.7.15 Released
Enhancements: 02/21/2025
Added Router Protection support.
Bug Fixes:
Fixed a WiFi connection stability issue.
Fixed various bugs.
Security Fixes:
This firmware addresses securit...
tmk1991
Apr 22, 2025Aspirant
Orbi 960 constantly rebooting randomly throughout the day at no specific time. Tried re-installing firmware and same result. Just rolled back to V7.2.6.21 to see if it helps.
Apr 23, 2025Guru - Experienced User
Does the front LED on the RBR turn PINK and blink white when this happens?
Does the UpTime on the RBRs web page under Advanced Tab/Show Stats have same time frame change as the routers IP address/debug.htm?
It's mentioned in the first post for this thread that if issues are seen after a FW update, to perform a factory reset and setup from scratch. I did this on my 850 series and saw 30 days good up time with no reboots. Not same HW however same FW code base. Please give this a try with v.15 FW loaded.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended. I saw odd reboot issues a couple of years ago on my 850 and 960 series. Was using UTP cabling. After switching to STP cabling, no more reboots.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.
