Feb 22, 2025Guru - Experienced User
New - Orbi RBR/RBS 850/860 and 960 series Firmware Version 7.2.7.15 Released
Enhancements: 02/21/2025
Added Router Protection support.
Bug Fixes:
Fixed a WiFi connection stability issue.
Fixed various bugs.
Security Fixes:
This firmware addresses securit...
dtay
Apr 26, 2025Luminary
Updated to 7.2.7.15 about 40+ days ago for my RBK853 without any connectivity issues so far, but have noticed a weird oddity on "Attached Devices" pages that shows the connected clients/devices on the GUI, and some of the icons for the device type don't show up correctly:
Tried clearing the cache/history on the browsers and also tried different browsers (Chrome and Edge) and no difference.
Anybody seeing this weird issue as well?
- KMDonlonApr 26, 2025VirtuosoJust manually assign the missing icons, I noticed this when I updated and then reverted back to the previous firmware.
- Retired_MemberApr 27, 2025
I also had the issue with the icons missing for some devices aswell.
A factory reset and setup from scratch fixed this issue for me.
- FURRYe38Apr 27, 2025Guru - Experienced User
I haven't. Though I had installed FW and then factory reset and setup from scratch. It is posted in the first post that if odd issues are seen after a FW update, a factory reset may needed.
