Feb 22, 2025Guru - Experienced User
New - Orbi RBR/RBS 850/860 and 960 series Firmware Version 7.2.7.15 Released
Enhancements: 02/21/2025
Added Router Protection support.
Bug Fixes:
Fixed a WiFi connection stability issue.
Fixed various bugs.
Security Fixes:
This firmware addresses securit...
Retired_Member
May 22, 2025Just a quick update, I found that disabling all logging and then performing a full power cycle of my system—a step I came across in the post linked below (which discusses BE systems)—resulted in a significant performance improvement in my setup.
I was also encountering a connectivity issue with certain devices after 5–8 days, which required a full system reboot to resolve. After disabling logging, that issue seems to have been resolved as well. I thought this might be helpful to share in case others are facing similar problems.
https://community.netgear.com/discussions/en-home-orbi-be/orbi-be-series-troubleshooting-tips---reboots-and-crashes/2449415
