Dec 28, 2022Guru - Experienced User
New - RBK653 Firmware Version 4.6.14.3 Released
Security Fixes: 12/05/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
Bug Fixes:
Moves the Au...
lyr1cx
Jan 22, 2023Initiate
I was able to update my RBS350 Sats that were included with my RBR750. In my case the RBR750 had upgraded to 4.6.14.3 by itself and the satellites did not auto update. As a result the satellites were constantly out of sync, errors, etc and not working correctly because they were behind on firmware.
I had to log into them manually after figuring out their two dedicated local IPs. The username/password is the same as the main router for other users that may be coming from google / elsewhere to find a solution.
This fixed that, thank you!
- FURRYe38Mar 29, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. đĄ- M-5Oct 04, 2023Guide
Any insights into when the latest firmware for the RBS350s will be out? I have an RBR750 but the satellites are RSB350s...I'm surprised that they don't have the 7.x firmware yet.
- FURRYe38Oct 04, 2023Guru - Experienced User
You don't have the RBR350?
Is your system a RBK350 series or something different?
Are you having problems with this system?
