Dec 28, 2022Guru - Experienced User
New - RBK653 Firmware Version 4.6.14.3 Released
Security Fixes: 12/05/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
Bug Fixes:
Moves the Au...
Mar 29, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
M-5
Oct 04, 2023Guide
Any insights into when the latest firmware for the RBS350s will be out? I have an RBR750 but the satellites are RSB350s...I'm surprised that they don't have the 7.x firmware yet.
- FURRYe38Oct 04, 2023Guru - Experienced User
You don't have the RBR350?
Is your system a RBK350 series or something different?
Are you having problems with this system?
- M-5Oct 04, 2023Guide
It's an RBK653 system...RBR750 plus 2xRBS350.
All are V4.6.14.3, but I saw that the RBR750 has 7.2.6.21 and wondered when the satellites were catching up; I don't like to mix versions.
It's working fine as-is.
There we go, I forgot about the 650 series. Yes be sure to keep the RBS and RBR at the same level from the RBK653 download site. Don't mix from the RBK750 series site. I'll check and see.
