Dec 28, 2022Guru - Experienced User
New - RBK653 Firmware Version 4.6.14.3 Released
Security Fixes: 12/05/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
Bug Fixes:
Moves the Au...
M-5
Oct 20, 2023Guide
Any update on the firmware?
Oct 20, 2023Guru - Experienced User
Nothing to date.
- M-5Dec 22, 2023Guide
Any update? It seems like quite a while...I think it's shabby to update a router and not update all the compatible satellites SOLD AS A KIT.
- FURRYe38Dec 22, 2023Guru - Experienced User
Something to contact NG support about and let them know.
Good Luck.
- M-5Mar 29, 2024Guide
I tried; no luck. It's really irritating to have a mass-market product left behind.
- FURRYe38Mar 29, 2024Guru - Experienced User
I believe that since the 750 and 350 series are technically different and 350s are only dual band supporting, can only presume that there maybe incompatibilities with newer FW that doesn't work on the 350 series. The 350 series was a budget system.
Something you can do, and try...find you some RBS750 series satellites, check places like amazon, ebay or shopgoodwill and if you can, replace the 350s, then update the RBS750s and RBR to v7 FW. Otherwise, use the system as is.
- JWaldnerJul 25, 2024Tutor
I'm having issues after updating the firmware on my RBR750 router to 7.2,.6.21. It will no longer sync with my RBS350 satellites. I have had to disable auto update and rollback the firmware on my router to 4.6.14.3 to get my satellites to sync. They are running the latest firm ware 4.4.1.29.
I just wanted to let everyone know, not to update if you have this similar configuration.
Thanks
- FURRYe38Jul 25, 2024Guru - Experienced User
RBS350 is not compatible with v7 FW loaded on RBR750s. You'll need to downgrade the RBR750 back to v4 FW:
I think I said that 🙂
Thanks
Enjoy. 📡
