Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
Jul 13, 2021Guru - Experienced User
This was mentioned to me:
https://kb.netgear.com/000062109/How-do-I-set-up-and-install-NETGEAR-Smart-Parental-Controls
Please review and let us know if you are able to set up SPC features...
- RavepantsJul 13, 2021Guide
Hopefully this is the right place to reply.
I have installed this version now and the DNS issues seem to be gone, the issue I am seeing now is when streaming video from my server (windows 10 from a SMB share to kodi) I am seeing random freezes and hangs in playback while the cache fills up again from time to time, and kodi reporting that the connection is too slow.
(I was not experiencing this issue with the stock firmware)
Wireless seems ok, and I havent had any issues with internet streaming services yet, ie netflix and amazon seem ok.
The RBS750 satellites are hard wired to the RBR750 router, and all other wireless devices connected to them seem fine so far.
I do have other ethernet devices connected to them, so I will do some more testing tomorrow.
Initially thoughts are positive as the DNS issues appear to have gone and browsing speed seems snapier so far.
I will report back once I have clarified a few more things and perhaps run a wireshark to see if i can find out where the slowdown/latency is occuring.
- FURRYe38Jul 13, 2021Guru - Experienced User
Keep us posted...
- RavepantsJul 14, 2021Guide
I did some more testing this morning and there is definitely some sort of congestion on the wired LAN side between the router and the satellite, I haven't had time to do a wirehsark yet (at work here) but I have done some arbitrary streaming and file copying tests, and RDP from my laptop to the server is freezing intermittently.
It's probably worth mentioning I have a teamed dual gig NIC in the win 10 box that serves the files, and a 8 port dumb switch connected to the satellite.
My next test will be to use a single NIC and test, then remove the switch and test, but i'll restate that the wired LAN side was working fine with the stock firmware.
I'll do a wireshark at some point and post my findings.
- FURRYe38Jul 14, 2021Guru - Experienced User
What is the brand and model# of the switch being used in the configuration?
Where is this switch placed and located at in the configuration?
Ravepants wrote:I did some more testing this morning and there is definitely some sort of congestion on the wired LAN side between the router and the satellite, I haven't had time to do a wirehsark yet (at work here) but I have done some arbitrary streaming and file copying tests, and RDP from my laptop to the server is freezing intermittently.
