Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
Durpquad
Jul 13, 2021Star
Updated my RBK752 this morning, been running great all day. Removed the static dns entries from my win10 box and haven't seen any dns issues yet. The parental controls are in the orbi app. So far looks like a well thought out setup.
- Mastra11Jul 14, 2021ApprenticeHi, so is everything working fine and stable? list of connected devices all ok? how did you update the firmware? Is this firmware also available directly from the router or only from the site and must be installed manually? thank you very much.
- FURRYe38Jul 14, 2021Guru - Experienced User
Thanks for letting us know and the orbi app screen shot. Glad SPC is finally making in to Orbi AX.
Enjoy. 📡
Durpquad wrote:
Updated my RBK752 this morning, been running great all day. Removed the static dns entries from my win10 box and haven't seen any dns issues yet. The parental controls are in the orbi app. So far looks like a well thought out setup.- Mastra11Jul 14, 2021ApprenticeFURRYe38 Is this new firmware stable and working fine? Can it be installed directly from the router or is it available for download only from the site? thank you
I don't have the 7 series Orbi and it's not yet avialble for the 8 series which I have.
Yes you can install it manaully. I dont' know if it's up on NG auto update services as of yet so if it's not seen on the RBR as available, you can manually download it and install it. Install on the RBS first then RBR lastly. Power OFF the RBR and RBS for 30 seconds then back ON after FW has been updated.
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
Mastra11 wrote:
FURRYe38Is this new firmware stable and working fine? Can it be installed directly from the router or is it available for download only from the site? thank you
