Jul 13, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
Ravepants
Jul 14, 2021Guide
I did some more testing this morning and there is definitely some sort of congestion on the wired LAN side between the router and the satellite, I haven't had time to do a wirehsark yet (at work here) but I have done some arbitrary streaming and file copying tests, and RDP from my laptop to the server is freezing intermittently.
It's probably worth mentioning I have a teamed dual gig NIC in the win 10 box that serves the files, and a 8 port dumb switch connected to the satellite.
My next test will be to use a single NIC and test, then remove the switch and test, but i'll restate that the wired LAN side was working fine with the stock firmware.
I'll do a wireshark at some point and post my findings.
Jul 14, 2021Guru - Experienced User
What is the brand and model# of the switch being used in the configuration?
Where is this switch placed and located at in the configuration?
Ravepants wrote:I did some more testing this morning and there is definitely some sort of congestion on the wired LAN side between the router and the satellite, I haven't had time to do a wirehsark yet (at work here) but I have done some arbitrary streaming and file copying tests, and RDP from my laptop to the server is freezing intermittently.
- RavepantsJul 14, 2021Guide
Hiya,
the switch is a netgear GS308, I have attached a basic diagram, apolgies for the roughness.
- FURRYe38Jul 14, 2021Guru - Experienced User
Let us know what happens wtih out the switch in between...
- Mastra11Jul 14, 2021ApprenticeWhy do I always find firmware 3.2.18.1 when searching for the update directly from the router and this latest version is not? didn't they make it available there? thank you.
