Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
Jul 15, 2021Guru - Experienced User
Is this your ONT?
https://service-provider.zyxel.com/global/en/products/fiber-oltsonts/active-fiber/hgus/am3100-b0
RayBan_21
Jul 15, 2021Star
FURRYe38 Yes - looks like that's the one. Weird thing is that with Google Wifi, it runs smoothly (although slow - as expected) and it worked fine with the v3 FW until I tried upgrading with the latest NG FW (v4).
- FURRYe38Jul 15, 2021Guru - Experienced User
I think that ONT has a built in router.
Do you now if the ONT is bridged or working in router mode?
- RayBan_21Jul 16, 2021Star
FURRYe38 Tried following all your steps, but no luck. The zyxel is delivered by a service provider, sp not much I can change on that side. Also tried switching the RBR750 between router and AP mode without any changes. Service provider confirms all is good with the access. Also tried to re-upload the new FW, which went smoothly. Might be some settings I'm missing out on, but it seems to boil down to the ne FW... Tried yet again to upload the old FW, but it doesn't let me proceed (no "Yes"-button). D/L maxes out at 579 mbps, U/L at 943 mbps.
Any other pointers?
Thanks so far for all your help!
- FURRYe38Jul 16, 2021Guru - Experienced User
There a model # of the modem?
IF you tried AP mode and still saw DNS issues, that would be a ISP issue and not Orbi and AP mode is just pass thru for Data.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026You might try Voxels FW and see if there are differences:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883615#
https://www.snbforums.com/threads/custom-firmware-build-for-orbi-a-la-faq.65224/
You can revert back to stock FW if it doesn't work out for you.
