Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
ddkumar
Jul 16, 2021Star
The new firmware is a complete bust for me. Wireless throughput dropped to 20Mbit/sec from over 400Mbit/sec with an iPhone SE only 10 feet from the router. Even worse, I cannot manually retreat the firmware for the RBK750 because it prompts to ask if I really want to install older firmware but gives *NO* option to continue with the operation - only a visible cancel button to abort the update. I can retreat the satellite with no problem.
Christian_R
Jul 16, 2021NETGEAR Employee Retired
Hello Community,
The downgrade from FW v4.6.3.7 back to 3.2.18.1 is not supported. Therefore you will notice that there isn't an option to click "Yes". May you try performing a factory reset if you are attempting to revert back a firmware version and send me a private message if your issue persists.
Thanks,
Christian
- RayBan_21Jul 19, 2021Star
Christian_R I've sent you a private message, but haven't heard back from you.
Christian_R wrote:Hello Community,
Thanks,Christian
