Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
Africansun
Aug 03, 2021Tutor
I have an RBR750 with one RBS750 attached.
Was connected to cable modem by Ethernet and running in AP mode. All working great.
Recently was prompted to update firmware by orbi app. Now Wi-Fi completely unstable in AP mode - allowing connection for seconds at a time. Works ok in router mode but blocks internal traffic to server attached to cable modem. Completely useless since firmware update last week. I have tried rolling back the firmware - can do so on Satellite but blocked on router.
Major bug in new firmware. Any suggestions?
- FURRYe38Aug 03, 2021Guru - Experienced User
Factory reset and setup from scratch with same version on both RBR and RBS.
Africansun wrote:I have an RBR750 with one RBS750 attached.
Major bug in new firmware. Any suggestions?- AfricansunAug 03, 2021Tutor
Hi FURRYe38
Thanks for the response.
I have factory reset twice - and set up.
Both router and satellite on the same firmware (4.6.3.7).Problem comes when I change from Router to AP mode (as it was before the firmware upgrade).
The wifi connects devices for about 30 seconds and then drops - and network disappears from available networks on phone, tablet and laptops.
becomes totally unresponsive.
- Gatorade2000Aug 03, 2021Apprentice, next suggestion will be donate your orbi and buy something else. Here , it is so easy to say factory reset the device. I havent seen an official statement from Netgear yet. Their paid support after 90days is a scam too.I buy their stuff from Costco and dump it back if there is such an issue
- DieselroseAug 03, 2021TutorRBR750 and this new update has reduced my speeds form 900MBPS to 600MBPS, and capped the RBS750 Ethernet connected devices with CAT 6 cables to 95MBPS.
What’s the deal?!?!
Fix this.- Gatorade2000Aug 03, 2021ApprenticeDeal is **bleep**ty engineers. Buy their platinum plan.
Is this speed result with the RBRs speed test app on it's web page or thru a external speed test app?
Has a factory reset and setup from scratch been performed since last FW update on the RBR and RBS?
What’s the deal?!?!
Fix this.- DieselroseAug 03, 2021TutorThe 900MBPS speed test vs 600MBPS speed test was via the app.
The download speed of 95MBPS is me visually watching it via the Xbox.
If I switch the Xbox to wifi it downloads at 270MBPS vs Ethernet which caps out at 95MBPS.
Before this firmware update ethernet, which is CAT 6 cable, was fine.
