Jul 13, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
Aug 04, 2021Guru - Experienced User
Is this speed result with the RBRs speed test app on it's web page or thru a external speed test app?
Has a factory reset and setup from scratch been performed since last FW update on the RBR and RBS?
Dieselrose wrote:
RBR750 and this new update has reduced my speeds form 900MBPS to 600MBPS, and capped the RBS750 Ethernet connected devices with CAT 6 cables to 95MBPS.
What’s the deal?!?!
Fix this.
Dieselrose
Aug 04, 2021Tutor
The 900MBPS speed test vs 600MBPS speed test was via the app.
The download speed of 95MBPS is me visually watching it via the Xbox.
If I switch the Xbox to wifi it downloads at 270MBPS vs Ethernet which caps out at 95MBPS.
Before this firmware update ethernet, which is CAT 6 cable, was fine.
- FURRYe38Aug 04, 2021Guru - Experienced User
There is a known issue with the RBRs speed test app and I believe Orbi app not reporting 900Mpbs speeds correctly for those with 1Gb service. However actual speed results using a external speedtest app like Ooklas reports the full 900Mpbs.
You might factory reset the RBR and RBS and setup from scratch. Power OFF The RBS for 30 seconds then back ON then try speed testing at the RBS with xbox.
