Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
Aug 11, 2021Guru - Experienced User
In meantime, has ANYONE in this thread attempted to down grade from v4 to v3 and was it successful?
Seeing some post saying they've been able to down grade.
Try to find out which v3 versions they used and what browser...
Gatorade2000
Aug 11, 2021Apprentice
You can downgrade satellite but not the main router. There is no fking “yes” button to proceed.
- wjbridgeAug 11, 2021Star
Gatorade2000 wrote:
You can downgrade satellite but not the main router. There is no fking “yes” button to proceed.I have also downgraded the satellite to the v3 firmware only to find out it upgraded itself the next day. There is no way to "disable" the updates to my knowledge. I have tried blocking the updates domains though through my custom DNS service (AdGuardHome). I wish there was a feature like Windows at least to disable any major updates (i.e. v3 to v4) for 90 days so the bugs can be worked out.
- remsreefAug 11, 2021GuideLetting us downgrade to the previous version would fix the problem. Or, just renaming the previous version to 4.6.3.8 so we can “update” to the previous version would work too. I had to run out and buy another mesh router until this issue is resolved. :(
remsreef wrote:
Letting us downgrade to the previous version would fix the problem. Or, just renaming the previous version to 4.6.3.8 so we can “update” to the previous version would work too. I had to run out and buy another mesh router until this issue is resolved. :(Agreed. What mesh router did you end up purchasing?
- remsreefAug 11, 2021GuideI bought the Arris Surfboard Max Mesh Wifi 6. It’s working well, but it’s not as good my Orbi with the previous FW version. There’s one area where the Orbi had great connectivity and speed, but this Arris Max is struggling with the router and satellite in the same spot. I hope they fix the Orbi firmware soon.
