Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
Gtjacket
Aug 14, 2021Tutor
Has anyone gotten any communications from the official NG support? Did they ask for any logs, provide any updates, acknowledge the issue with the satellite instability? I disabled AX features (without going through factory reset) and it seemed to actually make things worse. Trying to avoid time spent on all this workaround when clearly it is a bug in the firmware that needs to be fixed.
Aug 14, 2021Guru - Experienced User
NG is aware of problems with the FW. They don't give time frames on when new fixes will be forth coming.
Try a factory reset and setup from scratch.
Some other posters said they got better operation with AX mode disabled, so it may work so some, may not for others.
