Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
raven_au
Aug 24, 2021Virtuoso
FURRYe38 wrote:You guys can try this:
FW fixes don't happen over night.
But removing the current broken version so that people don't get the broken update pushed onto them or simply not advertising the broken version seems like the sensible thing to do.
Since they haven't done that you have to conclude they aren't taking the complaints seriously or simply don't believe the problems are serious since the developers obviously never use the routers themselves.
So when will there be an update to help with this ... one year ... two ...
Aug 24, 2021Guru - Experienced User
I agree and asked them about this.
Can't presume to know what developers are doing.
No router mfrs announces when new FW is forth coming.
- wjbridgeAug 24, 2021Star
So I downgraded by RBR750 and RBS750 to V3.2.18.1_1.4.14. I wanted to start completely fresh without using backups.
These were the steps I took:
1. Download latest v3 of the RBR750 and RBS750 firmware
2. Disconnect the WAN from the RBR750 (disconnect internet)
3. Downgrade the firmware to the RBS750 using two wired connections (desktop to RBR750 and RBR750 to RBS750)
4. Downgrade the firmware to the RBR750 using that HTML trick on the firmware update page [AWESOME BY THE WAY!]
5. Performed a factory reset on the RBR750 using the web menu and performed a hard factory reset (via reset button) on the RBS750
6. Setup the RBR750 and blocked the following services
- explore.netgear.com
- downloadcenter.netgear.com <- used during the firmware update page
- http.fw.updates1.netgear.com
- updates1.netgear.com
- devcom.up.netgear.com <- used during the firmware update page
- netgear-devrecog.fing.io <- used during the firmware update page
- netgearup-dev.s3-us-west-2.amazonaws.com <- used during router booting process
7. Setup my LAN, custom DHCP address reservations, and custom DNS server (AdguardHome)
8. Reconnected the WAN (enabled internet)
From my testing the router was still trying to contact the update servers even with the "block sites" in the blocked list. The router logs also did not indicate any block sites being well...blocked. Since I am using a custom DNS solution, my service blocked those domains listed above which resulted on the firmware update page of "Service unreachable". The blocked sites option is not a way of blocking updates. The non-custom DNS solution would be to flash V3.2.10.10 to have access to Telnet to the router and disable updates through setting variables in the nvram.
I am finally on the previous version of the firmware.
- FURRYe38Aug 24, 2021Guru - Experienced User
Good to hear that is working back on V3.
Thanks for letting us know.
- cpmassenAug 24, 2021Apprentice
I spent another 2-3 hours chatting with support last night becuase I still have 1 device (Samsung TV) that will not be given an IP appress to connect to the interent. I have 4 other Samsung TV's in the house that connect just fine so not sure why this one is not connecting. I confirmed that I can easily connect the TV via a hotspot on my phone. Last night I followed the guidance and factory reset and started over. The TV connected just fine once that reset took place. The satellite remained off and not connected during this process. Once I plugged in the satellite and the TV switched connection from the router to the satellite the TV lost internet connection and continues to not connect at all. Any ideas why this would be persisting still? They were of no help last night.
- Timothy88Aug 29, 2021Luminary
I have an RBK752 system running firmware version 4.6.3.7 and am seeing the router disconnect and turn magenta. I have a wired connection to the router and am unable to connect to any devices on the LAN or access the internet while in this state. If I launch the app it shows the status of the router to be red/disconnected. I can recover by using the Orbi app on my phone and rebooting the router once the router reboots then everything is good. Is this yet another problem with the firmware? Any ideas on what may help stabalize this or do I have to go back to my time capsule until Netgear can get it fixed? Any ideas on when Netgear will be releasing a fix for this debacle of an update?
- FURRYe38Aug 29, 2021Guru - Experienced User
- Gatorade2000Aug 29, 2021ApprenticeAll the 300 posts are about this. return your orbi as it may crap up on you when you need the most.
In other words just go back to my 10 year old time capsule.
